That is a beautiful track. You workmanship is very impressive. If I can ask, where did you purchase the vinyl netting material.
My current track build.
Originally posted by Daron View PostThat is a beautiful track. You workmanship is very impressive. If I can ask, where did you purchase the vinyl netting material.
https://www.samsbeauty.com/service/R...hoCnUEQAvD_BwE
I added a few above. It's a 17 MB zip file and I don't have all of them but if you gmail my nic I can send you the file.Come Race at The Trace!
Update 03/07/22:
Well, I'm back at it. I had a few things that had me sidetracked for a bit, nothing serious which is good.
I finally got started on the garage, I'm going to add lights, tool boxes and more to the inside.
I also came up with an easier way to make brick walls.
The old way took time as I had to measure and to scribe the mortar lines to create the brick look.
I had a friend 3d print a brick roller. I simply roll it over a piece of extruded foam.
It does take some pressure to get it to work. I'm going to have him make another smooth roller or just cut a wooden rolling pin to size. My plan to make it so I can just feed it through the two rollers, kind of like an old school washing machine wringer. Heck, I might even make it motorized, stay tuned.
Tycosaur
- Likes 4
WOW!!. I just saw this thread and Wow!. Great looking track.
stumbled on the thread at the toolboxes made from extruded foam and then went back thru to the beginning of the track build. talent to make it look great.Last edited by lance; March 20, 2022, 02:37 PM.Lance Sofa racer, SA TX by way of Hawaii
I've been busy in the garage loft with the conversion from the slot car area to wood /craft shop area. I finally got the Onefinity CNC up and running and have built my first project this week.
This is one of 3 driver stations that I created, I was never a fan of the screw stems hookups that stick out and so I came up with this idea. I used bottle caps as covers for the hookups, it also has a tire cleaning area. I plan to finish lanes 1 and 3 this week along with the controller bracket.
TycosaurLast edited by Tycosaur; May 23, 2022, 04:07 AM.
- Likes 3
Wrangler#3, the tire cleaning area is tapped into each lane and can be controlled independently. I was going to have them all powered by a 12v adapter but thought it would be better this way. I did leave the brake wire off as well.
