Revoslot Cars and Specifications
  • Revoslot Cars and Specifications
    Gentlemen, here are the pictures of the cars. All of the cars are within spec for width, ground clearance, motors and gearing.
    MEASUREMENTS
    WEIGHT : Taken on my standard 7.00 jewelers scale
    CLEARANCE: USED MY STANDARD 1.00mm gauge no car was close
    F/R TRACK MEASUREMENT: Taken from the edge of the contact patch to the edge of the contact patch
    TIRE WIDTH: Measured at the contact patch not including rounded edge
    It was interesting to note how many cars that appear the same can have varying degrees of measurements. I will be curious to see how the GT2 911 cars perform with their f/r track width differences, same with the Vipers as they are all over the place. Definitely this will be a learning experience for us all.
    If there are other changes please feel free to add if you have bushings instead of bearings etc. Additionally, we have approximately 6-7 shallow guides that will ship with the cars and I will order additional guides to go to our second host, thank you Ragtopman for including the extras. Thank you for your entries and I hope that you enjoy the proxy and I wish you all the best.
    Click image for larger version  Name:	A8BF026A-AD28-4D42-BAF3-F2BF7191C94B.jpeg Views:	31 Size:	2.50 MB ID:	98813
    The Jester
    Soxside (Chicago)
    MANCHVEGASRACER #91
    weight. 100.8 grams
    front tire width 8.33mm
    Front Track 60.86mm
    Rear Tire Width 11.59mm
    Rear Track 62.93mm
    Guide Shallow
    The Jester
    Soxside (Chicago)
    • manchvegasracer
      manchvegasracer commented
      That’s a bummer. I suppose it wasn’t handled very well by USPS. Thanks for repairing it. Not looking good to stay on during racing. Ugh.
    • Brumos RSR
      Brumos RSR commented
      I think it will be ok. I did not ca glue it as it’s close to the window and I didn’t want it to fog. We are starting at your track. And I’m fine with you taking a second look at it.
    • manchvegasracer
      Ok. 👍🏻 Really looking forward to running these cars!
    RAGTOPMAN #88
    weight. 100.00grams
    front tire width 7.95mm
    Front Track 59.75mm
    Rear Tire Width. 11.44mm
    Rear Track 63.41mm
    Guide Deep
    The Jester
    Soxside (Chicago)
      DOC DOOM #62
      Weight. 108.9grams
      Front tire width 8.83mm
      Front Track 60.45mm
      Rear Tire Width 11.30mm
      Rear Track 62.81mm
      Guide Deep
      The Jester
      Soxside (Chicago)
        Click image for larger version  Name:	9FD5FDA0-79D0-414E-B88D-B59906201C1D.jpeg Views:	0 Size:	1.63 MB ID:	98828
        MODLERSC #60
        Weight 100.8 grams
        Front tire width. 9.36mm
        Front Track 60.24mm
        Rear Tire Width 10..95mm
        Rear Track 62.07mm
        Guide. Shallow
        rear valence removed
        The Jester
        Soxside (Chicago)
          ALHOA #6
          Weight. 100.8grams
          front tire width 9.16mm
          Front Track 60.64mm
          Rear Tire Width 10.81mm
          Rear Track 63.17mm
          Guide Deep
          The Jester
          Soxside (Chicago)
            GSNOPOINT #4
            Weight. 102.2 grams
            front tire width 9.34mm
            Front Track 60.34mm
            Rear Tire Width 10.82mm
            Rear Track 63.33mm
            Guide Deep
            The Jester
            Soxside (Chicago)
              AUSTIN #44
              Weight. 100.4 grams
              front tire width. 9.12mm
              Front Track 58.43mm
              Rear Tire Width 11.12mm
              Rear Track 61.22mm
              Guide Deep
              The Jester
              Soxside (Chicago)
              • cj74
                cj74 commented
                Looks very good Austin. Well done!
              • r377
                r377 commented
                what body and chassis is that ? nice
              • Brumos RSR
                Fly Venturi body on a Revoslot Viper chassis
              Click image for larger version  Name:	C0A5E14C-715E-4311-B2D7-551CFCC4861D.jpeg Views:	49 Size:	1.45 MB ID:	98838
              REL13 #90
              Weight. 100.0 grams
              front tire width 8.31mm
              Front Track 64.23mm
              Rear Tire Width. 10.50mm
              Rear Track 62.70mm
              Guide Shallow
              The Jester
              Soxside (Chicago)
                Click image for larger version  Name:	36E4ED4A-70D4-4DB1-BF61-A4DB8D0DC95C.jpeg Views:	0 Size:	1.55 MB ID:	98841
                REL13 #89
                Weight. 98.1grams
                front tire width. 8.29mm
                Front Track 64.23mm
                Rear Track 63.40mm
                Guide. Shallow
                The Jester
                Soxside (Chicago)
                  BRUMOS RSR #33
                  Weight. 88.1 grams
                  front tire width. 8.33mm
                  Front Track 62.00mm
                  Rear Tire Width 11.48mm
                  Rear Track 64.23mm
                  Guide Deep
                  Champion Lexan interior
                  carbon axles
                  The Jester
                  Soxside (Chicago)
                    STEEVEEW #24
                    Weight. 98.7grams
                    Front Track 61.50mm
                    Rear Tire Width. 10.93mm
                    Rear Track 60.24mm
                    Guide Shallow
                    The Jester
                    Soxside (Chicago)
                      DOUBL-B #5
                      Weight. 112.8grams
                      front tire width 9.07mm
                      Front Track 59.90mm
                      Rear Track 64.08mm
                      Guide Shallow
                      The Jester
                      Soxside (Chicago)
                        BRUMOS RSR #3
                        Weight. 96.2grams
                        front tire width 9.10mm
                        Front Track 60.47mm
                        Rear Tire Width 11.20mm
                        Rear Track 64.27mm
                        Guide Deep
                        25 shore
                        Slot It Ferrari F40 interior
                        carbon axles
                        The Jester
                        Soxside (Chicago)
                          Reserved for
                          ARROLDN #1
                          The Jester
                          Soxside (Chicago)
