- Likes 3
I did the hot water in the oven thing on three Racer/Sideways Daytona Prototype chassis. It made them brittle and all three of them broke. I tried it on an NSR chassis and it melted it.
Looks like this tool might work.Butch Dunaway
Oxford, Ohio
I have maybe 100 cars and only ever tried to straighten one chassis with hot water, a SlotIt Opel DTM, it was boiling water and badly distorted the chassis...this was about 5 years ago...I've not felt the need to try again.Kevan - Isle of Man
There's quite a difference between 'hot' and 'boiling'. The hot water method has worked for me, wouldn't dare try boiling water. Just hot enough to soften or 'relax' the plastic is all that's needed. No need to use a sledge hammer to kill a mosquito.
How the chassis cools probably also has an effect of the outcome. I left the chassis in the water overnight and let everything cool back down to room temperature slowly.
yes steel plate + lots of the magnets i have accumulated + hot water works for me
now warped /twisted bodies ? thats a different matter , a straightener for those would be great
must admit it does look the part thoughKev
Burnley
England🇬🇧
Hot water works for warped bodyshells, hot enough that you can keep your finger in without burning is safest...works wonders on resin and 3D bodyshells too.
Hold bodyshell in the water for 10 seconds, take out and straighten bodyshell, run under cold water whilst holding it straight, repeat if necessary.
...bear in mind heat welded interiors can hold a warp into a bodyshell.
Matt, you know how guys will buy a dozen motors in hopes they will get one fast one. I buy a dozen chassis in hopes that I will get one straight one.Butch Dunaway
Oxford, Ohio
I did totally ruin a 69 Nova body with water that was too hot
It was garbage in less than 3 seconds
Dont know if I’m right or not but I firmly believe the colour of the moulding affects weather it is workable easily or delicateDave
