I have not tried the latest Dash brushes, I normally use Wizzard brushes and I have also tried the Slottech brushes. The Slottech brushes are slightly larger in diameter and may hang up in a Dash chassis unless you enlarge the brush holes.
I have used both the Wizzard and Dash older V-bottom (still available) brushes with good success in my Friday night chassis cars. In fact one of the entries in the proxy has Wizzard brushes in it as one of the factory brushes was cracked. I think you will be happy with either flavor!
