Need some advice
  • Need some advice
    Just joined the forum a few weeks ago. This is my first post. My wife was doing some spring cleaning and came across an HO set .
    Started watching some you tube videos and got bit by the bug. The set is Hot Wheels Battle Slam.
    The cars won't run. Don't know if it's the cars or the controls or the power pack. Don't know the next step.
    Any advice would be appreciated.
    Thanks, Paul
    Thanks, Paul
    Follow the juice. When plugged in does the power pack ‘hum?’ Assuming it’s a wall wart. If it does, is it putting out power? Next, is that power getting to the track? Check connections with voltmeter. If it’s getting to the track, is it getting to the cars? Put volt meter probes on track rails, power pack on, controller engaged. If so, check pickups on cars. Intact? Connections from pickups to motor intact?
    Drive wheels on cars not stuck?
      Clean the cars and track. Pay special attention to the joints that connect track sections together. Lightly oil the motor bearings and test the cars on a power supply or 9V battery. Once the cars are running then you can start testing the track. Do you have the service manual?
      https://service.mattel.com//instruct...BATTLESLAM.pdf
        Thanks for the replies, I'll follow the juice. I'll invest in a volt ohm meter
          An automotive light bulb and test leads will do the same thing
          a bright light is good power
            Sometimes, if things have been sitting a while, all you have to do is simply finger roll the rear wheels; so the brushes scuff the tarnish off the commutator in the motors. Sounds dumb, but it's common.
              Thanks everybody. The cars do work. I'm going to check the transformer Again tomorrow. Thanks again
