New Parts #'s for Proxy
  • New Parts #'s for Proxy
    Is any size " Ultra Tire " that's on the RT-HO site ok to use?
    Meaning the 4 sizes that fit the RT-135 wheels.
    UT-333 0.333
    UT-337 0.337
    UT-355 0.343
    UT-359 0.347
    And any size " Super Tire " as well?
    Meaning the 5 sizes that fit the RT-135.
    ST-316 0.328
    ST-320 0.332
    ST-324 0.336
    ST-328 0.340
    ST-332 0.344
    Are these " Pro Series " Super Tires?
    If these are the ones, I want to compare to the old tires and test them to see which ones are better.
    And the 2 sizes of front ends are the same as last time too?
    RT-245
    RT-255
    Thanks!
    The Super Tires should be from the Pro Series. Those were originally designed to fit 0.188" diameter wheels, when you put them on 0.170" diameter wheels they are stretched less and will be a bit softer. The Pro Series chart on the Super Tires site shows the mounted diameter for each part number tire on both diameter wheels. I was told that Rick Terry would no longer be selling his own tires, I will have to check on that however. In any case if both makes are legal you should try them both and run with the ones that work best for you.
      Thanks for the info, Rich!
