I needed some flat surface plates so I repurposed some free Quartz countertop samples. They are flat and shouldn't bend. Quartz countertops are a composite material and it was easy to drill the hole for the guide pin. I marked the hole location with a sharpie and Goof Off removed all traces of the markup. After the hole was drilled I used a larger bit to slightly countersink the hole to make it easier to locate. Repurposing something that otherwise would be thrown away is always good.
Flat Surface Plate
Flat Surface Plate
I needed some flat surface plates so I repurposed some free Quartz countertop samples. They are flat and shouldn't bend. Quartz countertops are a composite material and it was easy to drill the hole for the guide pin. I marked the hole location with a sharpie and Goof Off removed all traces of the markup. After the hole was drilled I used a larger bit to slightly countersink the hole to make it easier to locate. Repurposing something that otherwise would be thrown away is always good.1 PhotoLast edited by Maddman; December 4, 2021, 05:44 PM.Tags: None
- 2 likes
Years ago, some guy was pushing setup blocks made from 1/4" plexiglass for a ridiculous price. I went to a cabinet shop and got scraps of Corian for free and made better ones for everybody on HRW who wanted one for the cost of the VHS tape-sized Priority mailing boxes. There were hundreds of them, and I had a ball cutting them out and grooving a slot in them. We never heard from the jerk or his plexiglass again. Victory is still sweet all these years later.
