Starting my Magnatraction Javelin
  • Starting my Magnatraction Javelin
    I picked up 5 Magnatraction chassis today to test, I will be setting them up for a
    Javelin
    AFX body I have. Be getting the body ready for paint today.
    Austin
    Merrimack, NH
    This should be interesting!
      Click image for larger version  Name:	DSC00785.JPG Views:	0 Size:	152.8 KB ID:	11785Click image for larger version  Name:	DSC00782.JPG Views:	0 Size:	154.5 KB ID:	11781Click image for larger version  Name:	DSC00783.JPG Views:	0 Size:	155.8 KB ID:	11782Click image for larger version  Name:	DSC00781.JPG Views:	0 Size:	157.4 KB ID:	11783Click image for larger version  Name:	DSC00784.JPG Views:	0 Size:	147.8 KB ID:	11784
      Two bodies party painted and the magnetic downforce of two chassis and the chassis weight
      Next chassis tear down and rebuild., I got the 5 chassis for $40 USED
      one of the chassis has front half of the top plate is missing DO NOT DO THIS
      Austin
      Merrimack, NH
        well the first thing I found when taking one apart was that the motor magnets were glued in place.
        Now lets check the
        ARMATURES:
        1. Stock AFX M/T Gold wire with red ends is the only Aurora armature allowed.
        4. Arms must measure between 13.8 and 16.5 ohms between poles.
        Mine has red ends with green wire, I do have 1 with red ends and gold wire. I think I will test them both.
        Red wire test around 14 / 15
        gold wire test around 6
        That's way the rules say red wire
ID:	11945Click image for larger version
ID:	11946Click image for larger version
        Austin
        Merrimack, NH
          As you can see I now have the Red ends with the gold wire
          ARMATURE in place
          Lets get it cleaned up and turn free with the top gears in place
          Click image for larger version  Name:	DSC00789.JPG Views:	0 Size:	156.1 KB ID:	11949Click image for larger version  Name:	DSC00790.JPG Views:	0 Size:	152.8 KB ID:	11950
          Be sure every thig is clean before putting back together. I use Viper Juice to lightly oil moving parts
          Austin
          Merrimack, NH
            For wheels I got two sets of RRR tomy wheel sets. 952C and 953C. So lets put them on and see how true they are.
            Austin
            Merrimack, NH
              The RRR rear wheels were not all that true, just might get rid of them.
              Tested the newer green tip gold wire auto world armature 15 / 15.5 so the looks good for this race
              Austin
              Merrimack, NH
                looking good Don, I`m working on a couple cars, Viper & Chevelle 454, by the way, what have you decided on the AW/JL arms. here are 3 checks I`ve done, all 3 above what the spec is set at ?
ID:	12207Click image for larger version
ID:	12208Click image for larger version
ID:	12209Click image for larger version
                Mark
                  You can run higher ohms just not lower, The lower the ohms adds a little more speed ( or power )
                  The ones I test was 15/ 16.5 from a Auto World x-traction not a ultra-g , I all so test on the solder but that shouldn't matter, I will change the rule, realy tring to keep the Mean greens and others at 6 ohms out
                  Do yours have the green tips with gold wire ?
                  Maybe should of had only Auto Worlds stock setup.
                  Austin
                  Merrimack, NH
                    Yes. all 3 green poles, gold wire.
                    Mark
                      Austin, I feel you pain in setting up a car.
                        Love the old Javelin and AMX bodies, great start! Is gluing HO magnets good, how do you determine where to glue them, air gap adjustment or? In 1/24 scale we used to center and glue the magnets.
