Looking for some current sources for wheels and tires for 1/43 cars. Primarily Carrera Go and SCX. Most of the sources I knew previously are no longer available.
Wheels and tires
www.slotcarstyres.com has urethane tires for Carrera Go! rally cars. Not sure what else they would fit.
I got tires from him for Kyosho DSlot cars; worked great.
- 1 like
Peter ( pfuetze ) is so modest...
Bill, go to SHAPEWAYS and enter "pfuetze". You will find a big selection of printed wheels. And what is even better - if you need some special dimensions or so, mail Peter and he surely will help you.
Greetings,
Roland
- 2 likes
This was exactly what I was looking for. Some new sources of tires and wheels. I thought I had seen some custom rims on one of Pfuetze's post but wasn't sure where to find it. All that I was aware of are Super Tires for SCX NASCAR, a few JelClaws and a brand called Ortman with look pretty rough in the photos.
i can make the Nomad inserts fit to the SCX Nascar wheels, no problem!
Carsten in Germany did a selection of tires, partly especially for my wheels, the 11.5 x 7 comes with low profile comes to my mind, also the 10x7 was a special size in low profile.
for the other sizes - Ortmann is doing great tires in 10mm with 6, 8 and 10mm width.
They can be fitted to 10mm and 11mm wheels easily. They need to be glued on, but this is easy on the printed wheels. the 11.5 and 12mm can be fitted with the 10mm tires, too, but they are a little stretched (i do not like that), but still work great. you can get the ortmann tires from ebay.
I paint the printed wheels with Revell color in silver and brush, but i have seen airbrush painting the wheels, too.
SCX compact tires - Ortmann makes special tires for some SCX cars and Carrera go! cars.
They fit also on the printed wheels.
for small projects, there is an Ortmann tire with 9x13x7mm
for wheel inserts - it is way cheaper to combine wheel insert before printing. i need to know your wishes, than i do the combining and make a one piece print for you on shapeways. there should be some examples already available under the "wheel insert" section of the shop.
SCX compact Nascar wheels (3D printed) http://shpws.me/RSGx
Nomad style wheel inserts for printed Nascar wheels http://shpws.me/RSGy
attention: combined wheel inserts are way cheaper due to the high base costs of the detail material of the wheel inserts! send me a PM if interested.
Originally posted by elcaminobill View PostDo they provide a way to get the discount by combining inserts with the wheels, like you recommended? The only Nomad inserts I saw looked like they were too big for the SCX NASCAR wheels
for the Nomad inserts - the inserts in the link posted above are the correct ones! outside diameter 7.4mm to fit into the printed SCXcNascar wheels.
