With a large number of proxies running glued and trued rubber or urethane, I wondered if we were missing an opportunity to run different tracks and capture a different audience by running silicone. So then I wondered, what if I could build a couple of proxy cars and not spend hours away from my family just working on tires. Hence the idea of a slip-on proxy. While many hard core builders and proxy racers alike may be appalled, I've decided to press on to gauge interest and opportunity. So without further ado, on to the details:
Overview:
In an attempt to encourage interest, this proxy will consist of two classes. The first we'll call "stock" will be Scalectrix BTCC NGTC (Next Generation Touring Car). Even though I don't expect a number of straight out of the box entries, I do expect that everyone will respect the rules as written. The second class will be "modified" and will be open to both Scalextric and Slot.It Classic DTM cars (1984 - 1996). This class will be fore those that like to tinker! In both classes the rear tires will be limited to Quick Slicks silicone. More on that later...
The Proxy Event:
Race Format: Finishing order for each round of the proxy race and the entire series will be determined by the distance traveled and resulting points earned. Points will be awarded based on the total number of cars entered in the class. For example, in a 20 car field, the winner gets 20 points, second place gets 19, etc.
A minimum of 3 minutes racing time per car per lane is required at each track.
Each car is to be raced in a fair and equal manner and subject to the same track conditions. Lane and driver rotations to be determined by track host.
Once driver rotations have been established, they must remain consistent throughout the duration of the race. Any driver that has a car participating in the proxy MAY NOT race their own car on all lanes of the track.
All Track Hosts shall run the race using at least one driver available for each lane to be raced and a “race coordinator” that is off the track to assist with track calls, car moves, etc.
For example… A 3-lane track with all 3 lanes in use must have at least 4 people present and participating on race day.
Track hosts, this is a SILICONE proxy with SLIP ON tires. Please be mindful that tires may become unseated in an aggressive off. If so, a track call to re-seat the tire(s) is expected.
Tracks: This series will (hopefully) run at different 10 tracks. Tracks may be plastic or wood.
Track voltage should be set between 10-12 volts at the host’s discretion and shall be equal for all cars. If a potential host track typically runs outside this range, please contact me for consideration.
Registration Fee: The Registration Fee is $25 for the first entry and $20 for the second car. Entrants are limited to one car per class for this series. If the number of interested entrants exceeds the 40 spots available and an entrant is willing to give up a 2nd class any entry fees will be refunded. Entry fees are due This fee is due by July 15th Payment by PayPal is preferred to: https://paypal.me/slotracercj?locale.x=en_US (please include forum name and mailing address)
Due Date: All entries are due at the following address on or before – August 15th
Mailing address for cars is:
Corey Jett
15156 Charring Cross Ln
Monroe, MI 48161-5045
Sign-Up and Waiting List: The series is limited to 40 total cars. Position on the Sign-up sheet will be on a first come – first served basis. Those who sign up after the 40 slots are filled will be put on a Waiting List. As of May 8th, any racer on the Sign-Up list who has not paid his Registration Fee may have his slot taken by a racer from the Waiting List who does pay his Registration Fee. The mechanism for moving up from the Waiting List to the Sign-up List will be based on the last number racer on the Sign-Up list who has not paid his Registration Fee being vulnerable to the first number racer on the Waiting List who has paid his Registration Fee, and so forth. The reason for the May 1st Registration Fee deadline is to give races who move up from the Waiting List time to build and tune their entries.
The Proxy Rules:
General: No modifications/changes/upgrades permitted unless specifically stated in the rules below. Entrant’s name must be written on underside of chassis in paint, Sharpie, printed sticker or engraved. It is suggested that body screw adjustment information be provided on the underside of the chassis. Tape to cover screws is recommended, but not required.
Eligible Cars / Bodies:
Stock Class - Any 1/32 scale Scalextric BTCC (NGTC - vehicle years from 2011 - present) car is allowed.
Modified Class - Any 1/32 scale Scalextric or Slot it Classic (vehicle years from 1984 - 1996) DTM car is allowed.
Chassis: General - Traction magnets are NOT allowed.
Stock Class - Only stock Scalextric BTCC (car year 2011 or newer) non-podded plastic chassis may be used. Chassis may only be used for the body for which it was intended. Flashing may be removed from the chassis and light sanding to allow for body float (maximum gap of 1/32” between chassis and body) is acceptable. If a credit card can fit between the chassis and body the gap is too large. No other chassis modifications are allowed. Use of additional plastic or metal to strengthen/stiffen the chassis is NOT allowed. Lighting and associated wires may be removed, but is not required to be removed.
Modified Class - Any stock, 3D printed plastic, metal, brass or combination of 1/32 chassis is allowed. Metal chassis, including chassis with a combination of plastic and metal components are allowed. A different chassis than was intended for the car may be used. Updated chassis may be used (i.e. SlotIt EVO 6). Slot.it HRS chassis is allowed. The use of suspension is allowed. Tape is allowed across pod to control float.
Motor/Drivetrain: General - Motor cannot be opened for modification. 2WD only.
Stock Class - Motor may be glued or taped to chassis. Chassis modification to accept screws is NOT allowed.
Only 2 motors will be allowed:
Scalextric 18k stock motor (white, black or green endbell)
Gator 18k motor
Modified Class - Motor may be affixed to chassis or motor pod using glue, tape or screws.
Only 4 motors will be allowed:
Slot It 21k stock motor (MX15)
Gator 18k motor
Piranha 21.5k motor
Wheels and Axles: General - Wheels (font and rear) may be sanded to improve out of round condition. Important note - This is a slip-on proxy race. Removing too much material may result in poor fitting tires. Axle spacers (any brand) may be used to reduce side-to-side movement. Axle bushing may be glued into place.
Stock Class - Stock (or stock replacement) wheels and axle assembly (including stock plastic bushings) must be used.
Modified Class - Stock or replacement wheels may be used. Wheel size may not exceed 15.8 mm x 8.5 mm. Plain “insert” wheels must use inserts. Racing style wheels may be used without inserts. Wheel /tire must not protrude past the body when viewed from above. Stock wheels (if used) may be removed and replaced onto axle to eliminate wobble. Stock or aftermarket. Hollow axles are allowed. Axles must be 3/32” or 2.5mm (Ninco) in diameter. Any brand axle bushing may be used. Ball bearings (any brand) are allowed. Front axle screws (any brand) may be used and installed to adjust axle ride height. Independent front axle is allowed. Use of axle blocks is allowed. Front axle may not be “sleeved”or enclosed in any type of tubing.
Tires: General - Rear tires MUST be Quick Slicks silicone compound only. Size of tire must fit wheel chosen. ALL TIRES WILL BE CLOSELY INSPECTED FOR SIGNS OF GLUE AND/OR TRUING DURING PRE-SERIES TECH.
Stock Class - Tires (front or rear) may NOT be glued or trued.
Modified Class - Wheel /tire must not protrude past the body when viewed from above. Front tires may be glued, trued and coated to reduce friction. Rear tires may NOT be glued or trued.
*** Note *** Upon receipt of entry fee, each racer (entry) will be eligible to receive one set of Quick Slicks tires. If you would like to receive this set in time to support your build, please contact me via DM or leave a note in your entry fee payment with tire size and mailing address and I will coordinate delivery. If you do not require a set of tires for the build, you may request any size Quick Slicks tire to be returned with your proxy car.
Body / Interior: General - Exterior modifications to the body allowed are NOT allowed. Interior modifications to the body are NOT allowed. All “glass” that comes with a given stock body must be present. No tape is allowed on the exterior of the body or wing. Custom paint schemes are allowed. All cars must have a minimum of 3 printed/decal racing numbers consistent with the 1:1 liveries. If a fantasy livery is used, car must have a minimum of 3 printed/decal racing numbers (1 on each side and one visible from viewing the top of the car). If applicable, wing must be in place at the start of the proxy. Mirrors, antenna and other small components may be removed. Cars must have an interior.
Stock Class - Cars must use the stock an interior. Modifications to the interior/cockpit are NOT allowed. Cockpits may be taped or glued in place.
Modified Class - Lightweight glass is allowed. Stock or Lexan cockpits are allowed. Interior must be painted with at least 3 colors and driver must race suit may not be same color as general cockpit. Cockpits must be taped or glued in place.
Gears / Gear Ratio: General - None
Stock Class - Stock gears and gear ratio MUST be used.
Modified Class - All gearing is free choice of brand. Any gear ratio may be used.
Guide Flag: General - Note - Cars may run on both wood and plastic track. Any brand of 1/32 guide flag may be used, minor modification is allowed. The use of guide shims inside the guide hole to remove guide slop is allowed. Guide post may not be modified to strengthen. Any brand of pick up braid and motor wire is allowed. Guide must NOT extend beyond the front of the car. Only 1 guide flag may be used. Weight may not be permanently added within the guide flag.
Weight: General - All ballast must be securely fastened (tape or glue) to the inside of the car – it may be secured to the chassis and/or body. Only lead or tungsten ballast may be used. No weight on the bottom of the car or outside of the body. Weight may not be used to stiffen the chassis. Magnets may NOT be used as ballast. There is no minimum or maximum weight limit.
Ground Clearance: General - All cars must have at least 0.040” (or 1 mm) ground clearance.
28-Jan-20: Rule updates in ORANGE.
02-Feb-20: Rule updates in TEAL. Clarifying details around legal bodies.
09-May-20: Updated payment date to July 15th. Updated car due date to August 15th.
Overview:
The Proxy Event:
Corey Jett
The Proxy Rules:
Gator 18k motor
Gator 18k motor
Piranha 21.5k motor
