F1 Build Thread
  • F1 Build Thread
    Here is my first attempt , still need more testing but smooth so far, 65g.
ID:	917Click image for larger version
    Courtney Smith
    Chattanooga TN
    Looking good, Mine is right at 70g right now.
    My rear tires are shorter, so I need to some gearing changes, but it handles well.
      So I tested this friday night at the Atlanta commercial track it was SLOW. Geared 9/26
      When i installed the pinion i had to press it on , and my press pushes on the pinion and the shaft on the other end . The other end of this motor has the "closed bearing" would it possible that i pressed this closed end onto the shaft and damaged the motor?
      Courtney Smith
      Chattanooga TN
        I just recently put a 24t gear on my car. I pushed on the motor the same as you. It is not a very powerful little thing, gearing and rear tire diameter is going to change a lot.
        Zack
          If the endbell bushing cap does not appear to be crushed in any way you are likely OK.........there is at least 20/30 thou clearance between the armature shaft and the inside of the bushing cap on these motors.
          As far as gearing, you may want to consider going to a 23T Crown, or, a 10T pinion
            Well the number 57 is ready to ship. After a few tweaks it is running about 6 secs faster than last years car. Hopefully we can get some podiums.
            Click image for larger version  Name:	2020 HRW F1 .jpg Views:	1 Size:	316.3 KB ID:	5902
            Arrold Martin
            Nashville TN
              Well... Not having entered last year I don't know if shell be competitive, but felt good to me while testing. We shall see...
