Car Issues Found here in Nashville
  • Car Issues Found here in Nashville
    Pepsi62 Tire Rub COT car
    Click image for larger version  Name:	Pepsi62 COT tire rubbing chassis.jpg Views:	6 Size:	423.8 KB ID:	19584
    Moderator let me know if this should be fixed or let it continue on as is.
    Arrold Martin
    Nashville TN
    BWatkins Gear Stripped pinion did not engage on starting line. You can spin the rear axle and gears have no to limited mesh.
    Click image for larger version  Name:	GTO King Stripped Gear.jpg Views:	0 Size:	436.8 KB ID:	19586
    Moderator/Ken let me know if this should be fixed or DNF the car.
    Arrold Martin
    Nashville TN
    • Pepsi 62
      Pepsi 62 commented
      Hi Arroldn, you might be able to reset that wheel and give it enough clearance to run if allowed
    COY Pepsi62 Rear Axle Side to Side Play
Name:	Pepsi62 COY tire location 2.jpg
ID:	19588Click image for larger version
Name:	Pepsi62 COY tire location 3.jpg
ID:	19589Click image for larger version
Name:	Pepsi62 COY tire location.jpg
    Notice in picture 3 the wheel is moved inward. Moderator let me know if it is OK to fix are let it continue on.
    Arrold Martin
    Nashville TN
    • Pepsi 62
      Pepsi 62 commented
      is that the loose wheel on Car 40 or on 57??? I had used spacers on the inside of the pod between the crown and bushing to keep the mesh nice, feel free to check it out. if its an easy fix go for it
    I believe we have established past precedents that the host can repair a car.
    Myself, the nature of the failure determined what I would consider an non-intrusive repair... replacing a gear with a like kind I have done without asking/waiting for a response. Even shimming an axel so there is not tire rub I think would be allowed and appreciated. Clearly the cars will not be able to race well if at all with these issues. It is between you and the owner if you use your parts to repair and would like reimbursement. I know I have gladly done it in the past and have never wanted anything in return.
    DaVols Forums Cup Proxy Series
      It almost looks like a bearing popped out.
      Connecticut, U.S.A.
        Scott found this during qualifying. I have a tire on another car sitting around to replace it with. First time I've seen this. I have tires older than this one which have not done this. Glad it was caught here. Didn't seem to effect handling but wouldn't want it to fall apart later.
        Click image for larger version  Name:	#45 Rear Tire Purple .jpg Views:	0 Size:	251.6 KB ID:	19640
        Arrold Martin
        Nashville TN
        • k0z0oo1
          k0z0oo1 commented
          Is there a rub that is causing that, or is it just wearing from racing? Either way, go ahead and replace it so the car can continue
        • arroldn
          arroldn commented
          No rubbing. I have seen this happen to rubber tires. First time for urethane to my knowledge.
        • lance
          lance commented
          That reddish tire looks like what PG tires start doing after some time. PG urethane
        gee 2 outta 3 cars with issues, and this was the best the COY cars have done in qualy…….go figure
