Host Your Proxy Event on HRW!!!
HRW is the perfect place to host your proxy event with your own forum. Your proxy forum makes it easy to communicate schedules, rules, build info, race results and facilitate communication among participants. Please send a Private Message to "HRWForum" to get started.
See more
See less
Mustang Sportsman build
  • Mustang Sportsman build
ID:	4191 Got my parts today for the FORD entry. Thanks SLOTCARCORNER.COM
    Mark
    Looks like you're all set. Keep us updated.
      Oh yeah...it's on now.
        Looking forward to seeing this one done where did that Mustang body come from?
          It is the most recent body I made for myself, basically just a face lift for a 1 off body I did a few years ago.
          Mark
            Moving forward with some chassis work, nothing special just a basic solid unit, with float built between the body and chassis. . . kiss
            Mark
              Uh huh...it's pinned out and already looking fast.
                Mark
                  That is a great body. I think I see a Chevy/Ford pair from you hehe
                    no, they will both be Ford products.. body work about ready, mounting next
                    Mark
                      Love the front end of that machine. Side note, do most just use body filler like Bondo, or is there a better alternative?
                        Thanks ! I like to use bondo for big changes, also it allows you to decide your work time by your mix ratio.
                        However, the red you see here is also bondo brand, but is glazing putty in a tube. No mixing and if you cut your parts with a close tolerance, it works fine ...less sanding.
                        Mark
                          I used some different thickness plastic to set my tire clearance, and added my chassis to body supports. The body will be secured to the chassis with a single screw into the interior tray.
                          Mark
                            body painted
                            Mark
                              done, looks like the Modified will not make the big race, just not enough time.
ID:	12463Click image for larger version
ID:	12464Click image for larger version
ID:	12465Click image for larger version
                              Mark
