What are the recommended steps to prep a used slot car body (Scalextric) for painting? In particular, getting any decals off so I have a smooth surface.
Prepping a used slot car body for painting
Yup, 90% alcohol does the trick. Depending on the paint used it can take as little as 30 minutes or overnight if the paint is a tough one (some Fly cars or Ninco cars)Then I usually wash down the body with Westly's Tire Blech (sidewall cleaner) to remove any trace of oil/impurities left after the soak. A quick WET buff with 600 grit sandpaper to give the primer/paint something grip. Any of the sanding swirls at 600 grit will be eliminated with the first coat of primer or paint Look for casting lines too and remove them. If you use primer (gray or white), any imperfections will become noticeable real quick.
Buster
Nowhere near good enough for me, but thanks to the tips, my first two attempts came out okay for my use, but certainly not something I'm totally pleased with.
The Lola was initially sprayed with a cheap chinese clone of an Iwata and the paint was rough. Painted the racing stripes, and used some really thick decals that were on black background (note my late night oops with the upside down Martini decals! Should've gone to bed when my eyes were watering!).
The McLaren was done with a real Iwata airbrush, and came out noticeably better. Water slide decals on this one.
Hi
I know these are older posts but just a question along the same lines, any tips on prepping old Scalely, Eldon or Strombecker bodies for repaints. So the paint will stick to the old type plastic they used. Sorry if this question has been answered elsewhere already.
Have you tried 91% Isopropyl Alcohol bath just like in the video posted in post #6 ?
does that mean that the drugstores are out of it? must be people trying to make their own sand hanitizer. which one can now buy again.
when i wanted more than a small bottle of alcohol for something, i used to go buy a can of it at Cheapo Depot. i did notice that the last time i was in there, they didn't have any MEK. LOL
Depending on the age of the Scaleys in question, some are made of "tupperware" and will benefit from a quick sand with 800/1000 grit paper, and MUST be primed (unlike styrene). I have had very good luck with the "tupperware" Scaleys, using both Tamiya primer and Tamiya colour coats.
PS You can buy 99% Isopropyl at Shoppers Drug mart.........works a bit quicker than 91%.
Im kinda old school, and a fuss budget to boot. I like to use a "cleanser rouge" to ensure I get into shuts, seams, edges, and around the minute detail. AKA: all the places where paint jobs like to let go. My weapon of choice is a toothbrush with the bristles cut back a bit, to stiffen their approach. For really lumpy or raggy seams, I might employ one of those hard toothpicks, like the ones that hold your club sandwich together, in tandem with the cleanser.
Good luck!
Bill
