I've seen lots of body mounting methods. No one way is best, they all have their place and it's good to have a lot of options. This is how we mounted hard bodies when we were racing them at the local track, generally on an H&R chassis. I'll try to keep it short and clear. Have your body bare and ready for mounting.Have your chassis setup with tires and wheels.
Use a mounting bracket similar to this. This view is chassis side up. The space in the center is for lead wires if this is attached to a flat chassis.
I made a piece from balsa and used it to make a resin mold. Some guys cut them from 1/8-1/4 inch plastic sheet. Balsa wood is fine, too. It can even just be a single piece for each side. It doesn't have to be a solid piece like this. Sand the edges so it will fit in the body at the approximately the right place. Once fitted, center it on the chassis and mount with one screw. I like to use flush mounted screws tapered at the head. The screw will center itself in the hole when it's tight. You now have the frame with the mount screwed to it and the tires and wheels on it.
I use a paper towel cardboard insert to make tire covers as shown in the picture. Just cut about 1/2 wide and wrap around the tire and hold with some kind of clamp. Then put the chassis in place in the body.
You have the chassis where you want it with about 1/32 tire clearance. Use cya to glue mounts in place. Remove the one screw and pull the chassis off the mounts. Epoxy the mounts for a permanent attachment. Put the chassis back on and tighten your one screw. Center and drill the other 3 holes now. Basically done at this point. You can double wrap the cardboard for more clearance. You can also cut shims if your body is too low. I like flush mounted screws and if you want more body movement you can drill the chassis holes a bit bigger. It always helps to use a Dremel to round off the threads right at the bottom of the head.
Some of the guys were pretty rough and known to break glue joints, so I always tried to remember to sand the insides of the body to give the epoxy some tooth to hold onto.
This always worked for us to be an easy way to mount a body and not have interference between tires and body. Just another option.
