Hi,
Where I live, the Carrera track borders are prohibitively expensive. Second hand is difficult to find and most often the seller dosen't want to ship. Shipping new from other locations is not worth it, and for the time being I have made some borders from MDF, and painted them, which works OK. But they don't lend themselves to easily modifying the layout, and I've been thinking of changing my setup a bit. Same also for foam board which I have also used on parts of my layout. If it were flat, it would be easy as there are a few different materials that can be easily cut up to fit on a flat surface. (such as foam rubber, neoprene etc) But I am thinking of incorporating elevations. One idea was to cut more MDF, route a rebate, then epoxying the red Carrera track clips into the rebate and clipping it into the plastic track. But Has anyone else got any ideas?
edit: Just thought of coreflute... Texture is not ideal, but perhaps I should try it. I could cut it with a knife, and easily rebate the red track clips into it for a convenient solution. It may not work but its cheap enough to try I guess...
Thanks.
Thanks.
