What are people using for DIY jumper wires? I’m considering thermostat wire. It’s available as 18-gauge solid wire, 5 color-coded conductors in a PVC jacket. (Yes, 1 more wire than I need.). I figure the solid wire can be folded several times and friction-fit into the track without needing to solder proprietary clips on the end. Thoughts?
Jumper wires
Jumper wires
What are people using for DIY jumper wires? I’m considering thermostat wire. It’s available as 18-gauge solid wire, 5 color-coded conductors in a PVC jacket. (Yes, 1 more wire than I need.). I figure the solid wire can be folded several times and friction-fit into the track without needing to solder proprietary clips on the end. Thoughts?Tags: None
Originally posted by HomeRacingWorld View PostIf you strip stranded wire in longer sections, you can just insert them into the rails and seal with hot glue. Flexible stranded copper is much easier to work with than solid IMHO.
This has worked very well on several tracks I have built.Come Race at The Trace!
like they said, but try some individual 16gg in red and black and white from Home Depot, by the foot. Stranded works best.
It is cheaper to buy 25 foot of 14 gg with ground copper home wire. It is solid copper and a little harder to use, but it will work fine and you can use the ground wire (with a jumper) for common on both lanes and the black positive and white neutral wires for the positive leads to each lane. I have used this for all the tracks I've built. It is solid core and stripping 2-3 inches of insulation off the end lets you slide that wire inside a track rail with no soldering or gluing. It can be bent slightly to make it a tight fit.Matt B
