I'm having a hard time getting thin parts to print, I'm using flash print . I downloaded cura but I can't get it to work so flash print is it. Do I have to get a smaller nosil or can I just change some settings in the slicing?
The best way to do thin parts.
What do you call thin?
Printers normally come with a 0.4mm nozzle as standard, nobody is going to need anything thinner than that.
Maybe sending your stl file to a couple of volunteers to load into their slicer to see what they can do.
Prusa slicer is brilliant, I've used Cura and now use Qidi print as I have a Qidi printer which is basically Cura.Kevan - Isle of Man
There are settings in Cura that control the minimum length of a print segment or a layer. On small parts the distance the nozzle travels might be too small.
To be frank, printing small angled tubes is kinda tough without supports. That's why we tend to print a flat panel for a silhouette of the suspension.
Other setting to consider are speed (fine details are better at 30 vs 50/60), acceleration and jerk (the speed at which things change direction), as well as temp, flow, and retraction.
I run Cura 3.6 since I have had funky results with some of the V4 releases. Don't know Flashprint. I will say that Qidi slicer and Cura are similar but not identical and there is some magic in the Qidi software as racer1h uses it for great detail ( spark plugs wires for goodness sake) that I just can't get in Cura.Come Race at The Trace!
