I am sure anyone who owns a scalextric car has had the chassis crack at the rear bushings. Often the car is still able to be run because the body will hold the chassis together making it less than perfect but usable.
Now if you are like me and like to tweak and tune with the body off this can be a problem as the rear axle will often pop out. This was the case with my Camaro so I came up with a small fix that worked great. It printed in just a few minutes and after a touch of sanding I glued it in place. Good as new and stronger than stock.
Gipper
Gipper
