Before they wear out? I would think rubber wear out first, but I don't know about urethane or silicone. Replacing tires on 30+ cars on a regular basis could get expensive. So, I have been doing some research on masking my own. I just don't know if the wear rate justifies such a move.
I personally have found that my rubber tires will melt or dry out long before they wear out unless you have a tire truing fetish
The only set of tires that have worn out on me are NSR but theyโre the old rubber mix and VERY grippy when good
In most cases tires will last a long time for the average user
When they donโt I replace them with urethane and with over 300 cars I still have no desire to start casting my own
if that case you should get great tire life.. you make need to give the tires a slight wet sand was in a blue moon or a drop of nsr tire oil to the rubber if you do not run the car much but that would be it really.THE other Vancouver aka Vancouver Washington across the river from keep Portland weird....
I terms of number of laps before wearing out I'd say some normal rubber tyres have the shortest life, then Urethanes, then other normal rubber tyres then.............................................. .................................................. ................................way over here we have Silicones.Kevan - Isle of Man
Life is like a box of Slot cars...๐๐๐๐
- 1 like
I must have too many cars or simply don't use what I have often enough as I don't have a track and we only meet once a week. I've had tyres on cars go hard, melt or split while waiting their turn and none that I can recall get worn out enough before replacing. If a new car doesn't have suitable grip they get replaced right away.Last edited by Wobble; September 13, 2021, 04:14 PM.Bram,
CHCH NZ
depends. Track texture? plastic track or wood? wood with latex or wood with an additive? Area where you live, is it humid where rubber degrades quickly?
if stock tires, they can last years, or last couple of months and get hard or soft and sticky, (carrera tires). scaly tires good for long time.
if aftermarket tires, some rubber can last long or it can change and get too soft and ball up or show alligator pattern and loose traction.
urethane, some manufactures tires turn red orange after about 1 year and turn gooey. another mnufacturer has pretty good durability.
Dont know anything of silicon.Lance Sofa racer, SA TX by way of Hawaii
Been in this hobby 15 years โฆโฆ
I display all my cars, and put blocks under each which takes all the weight off the tires.
My intent was to eliminate flat spots, which by design or just good luck I have prevented.
Also the cars are not in direct sunlight and the track room is always a perfect 72 degrees
At this point the first cars of 15 years ago still run great on their Indy Grip - Max Professor Motor tires
Dundee Denny
