Carrera Brush Mod
Hello, I have done this on several Carrera cars, and there is no downside(s) whatsoever................a single piece of braid will not have as much "spring" as two pieces, and will therefore exert slightly less downward pressure on the track, which reduces the lift on the guide/front end. It is a small difference, but, a positive one, and, everything counts in small amounts
There is no advantage to running overly long braid strips, and I have often just cut the rear piece of braid from a two braid set-up...............same results, and very quick/easy to do.
We used to have some "rental" Carrera cars that were run on our Carrera commercial track, and all of them had the rear portion of the braid cut off,.........
I'd be concerned when running digital. The long braids could cause excessive shorts at lane changers. The CU has a 20ms timer and when it detects a short that last longer the CU will self protect.People don't stop playing because they get old, people get old because they stop playing.Comment
A little more involved but I’ve done this mod by completely removing the braid cutting it in half and then reinstalling in the clips. The second braid is then saved for a spare or another projectDave
CANADAComment
ive tried both ways. leaving it stock and letting the braid break in,seemed to work just fine. it didnt really act like a spring for me and laid flat. never had a conection or power problem.4 points of contact vs. 2 ?bill ,framingham maComment
