Is it better to allow the groove on in the crown gear to ensure gear mesh or should you use axle spacers to hold the mesh? If spacers are best, should you go ahead and trim the motor shaft to eliminate friction with the crown groove? I hope this question is clear. The wheels are set screw aluminum, not plastic press-ons.
Gears are slot.it.
I must add that this post was triggered by an answer to a gear noise question on another forum, SFI. I wanted to bring it to a broader audience for more discussion. Sorry for the initial lack of attribution.
Gears are slot.it.
