I'm adding cars to my Grand National-NASCAR series (ARCA & USAC stock cars too) mostly using Revell-Monogram bodies. I also have a '71 Torino resin cast body and a few more Proxie '71 Mercury Cyclone bodies. Whenever possible I'm using R-M, Pioneer, or Carrera chassis & parts for consistency of performance and style. The '71 Torino body has a 3 1/2" wheelbase which is shorter than those chassis, but Scalextric Challenger and Cougar chassis do fit it. The problem is those chassis have wheels that are out of place on a racing stock car from this era which had painted steel wheels.
All the cars in the series are box stock RTR with the only upgrade being silicone rear tires. Allowing after market metal wheels and axles would likely provide a performance advantage that's against the rules. I found a dealer that has plastic Pioneer 'steelie' wheels in stock, but not on axles. So the issue now becomes, is there a reliable way to remove press on plastic wheels and replace them with different ones? Over the years I've used super glue to replace two plastic wheels that came off, but it wasn't planned. I think in both cases the wheel that came off was on the spur gear side of a sidewinder rear axle and when replacing it I was able to glue it to the axle and the gear to fully secure them.
To put style correct wheels on this car, and others I might build, will mean replacing all 4 original wheels with Pioneer ones. Is this likely to work and if so, what recommendations do you have to help me out?
