I have enjoyed using the newish slot.it CH115 SW motor mount pod for ball bearings, especially when using it for semi-scratchbuilt chassis or conversions from inlines. Mostly using Piranha 25K BB motors, so I obviously needed to enlarge the can end mounting hole to fit the BB. Today, however, I tried to use an orange end bell slot.it and found that it was a very tight fit. It was unusually hard to push in at the can end and when finally in there was a gap between the motor and inside of the pod. When I tried to remove the motor to enlarge the hole the chassis broke just below the hole.
The “ears” above the are so narrow that the motor bearing pushed them apart causing the pod to flex so much that it broke. Figuring that it must have been a bad pod or my poor removal technique, I tried the other one I got with this one and despite being very careful got the same result.
I contacted SCC to see if anyone else had run into this and they checked with the distributor, Hornby, and this was the first either of them had heard of it. Thanks to these good people replacements are on the way. If they fit on these seems too tight, I will enlarge the hole instead of using too much force to install the motor.
BTW, the mfg code on these was 2021 189. I thought others might like the heads up. As I said, I really like these pods.
