Hello Guys , I am looking at trying my hand at painting my own cars , I have Testors Aztek paint system and want to mix my own colors . What I am looking for is the ratio of paint to thinner for this type of system . Any help will be appreciated .
Spray Painting
Try different mixes, spray on plastic spoons to see what is best. Then go for it!Scott.....War Eagle River......Tampa, Florida, USA
Chris is right...with an airbrush you want to not be watery, but not be thick either....hence the milk reference. General rule of thumb is bottle/brush paints are too thick, but it does depend a little on color and formulation. Also note that distance from the subject and technique matter....it's not always the paint or equipment. So the trial and error is reasonable, but milk is a good place to start.Come Race at The Trace!
I think you're being a little hard on yourself. It's not difficult, it's all about technique. With time you'll enhance your technique. Start off with single solid colors and don't over think it. Focus on spraying nice even layers onto a large white piece of construction paper to see how much paint is laid down in relation to how far away you are, trigger postion, etc. You'll get the hang of it pretty quick I think! And show us the work! we're all in it with you!
I've started to consider an airbrush system and have asked questions of builders during the weekly slot car zoom meetings. The value of using a compressor instead of a canned propellant was discussed and it will take practice to learn good techniques.
I'm considering where I can get some cheap models to practice on for multicolor paint schemes and fades where one color transitions smoothly to another. There are apt to be a lot of poor outcomes before being able to produce something to be proud of.
I didn't want to jump right into the compressor route right away , figured if I got good at using spray cans first then I would move up to using it
I get that, since the cost of a high quality airbrush and compressor could be $200 - $300. Iwata is what was recommended and what I checked out. Not sure I'll make the investment but if I do it'll be so I know what's possible with a good setup. If I can't get desired results with a good setup I'll know it's my lack of ability and move on.
What your doing makes sense (and cents) because you can always move up to a better setup in the future. Just don't let the results you get with the Testors airbrush and canned propellant convince you of the best you could do.
If you are going to use solvent based spray paint you should have a spray booth that vents outside or wear a mask that has a cartridge for organic vapors. The cartridge would need to be replaced from time to time. If you are spraying water based paint a simple dust mask would do.
