War Eagle, could I trouble you to take a close up picture of the front of this chassis? I'd like to see how you laid out your front axle, allowing wire to run under axle housing.( I think I know what you did) I also really like your full 1 piece plate up front adding strength, and holding your guide.
What thickness is your plate? Nice work Thank you
One32, the square tubing is sitting on top of the chassis rails, so there’s plenty of clearance between the front axle assembly and chassis/guide plate. .032 brass plate thickness
