Mirage M2 Coupe
  • Mirage M2 Coupe
    Building a resin copy of the elusive Aurora Mirage M2 Coupe, the hardest to find of the vintage 1/32 Aurora slot car bodies.
    Chassis will be the same metal/3D printed FF050 sidewinder motor pod as in my Ferrari 312Ps, another Aurora body resin copy.
    I've always liked dark blue rather than the iconic light blue, so that'll be the finish.
    Ahhhh.....the elusive Mirage. Wonderful body, looking forward to the build.
      Chassis's done.
      Click image for larger version  Name:	IMG-8293.jpg Views:	3 Size:	75.5 KB ID:	61811
      Click image for larger version  Name:	IMG-8295.jpg Views:	0 Size:	86.1 KB ID:	61814
      Same materials as usual.
      .055" piano wire - mail rails and front axle supports
      .032" piano wire - flexi side pan hinges
      .062" x 3/4" brass strip - front main plate
      .062" x 1/2" brass strip - guide tongue
      .062" x 1/4" brass strip - motor pod cross member supports
      .032" x 3/4" brass strip - side pans cut down to 14mm width
      5/32" brass tube - guide tube bored out to 9/64" to fit Sloting Plus Universal RSK guide
      1/8" brass tube - front axle tube, axle spacers
      Rest of components include,
      3D Ron resin printed FF050 sidewinder motor pod
      Scalextric Sport FF050 slimline green motor, 25K
      Slot It 10t sidewinder pinion, 6.5mm
      Slot It 36t spur gear, 19mm
      3/32" x 3/16" Parma oilites
      Slot It 15 x 8 plastic rims and Slot It tires at the front
      All Slot F1 rear rims and Paul Gage urethane tires at the rear
      Sloting Plus Universal RSK guide, 7mm deep
      Glad to report that it runs really well, smooth, planted in the corners with good straightline speed.
      Body's in paint prep stage with Tamiya putty filling the voids and sinks.
      Click image for larger version  Name:	IMG-8297.jpg Views:	3 Size:	53.9 KB ID:	61812
      Body mounting's next.
        Body's tri-post mounted.
        Stance is good.
        Wheel/tires clear fine.
        Turning out well.
          Sweet!
          Team SCANC
          Leadfinger Raceway
            Encountered some paint problems on the series of Tamiya blue paints with a few areas remaining wet after a few days. Think it's the resin mix as I did have the problem at the primer stage. Cleaned with alcohol and soap before re-primering but now it's come back.
            Moved ahead anyways with brush paint detailing and decaling.
            At least it runs really well.
              Very Cool!
                Looks great, Dan! Are you doing your own body masking or are those decals?
                  That looks great. Bet its going to run like a BEAST!
                    @ Audi1 - orange stripes were brush painted with the indispensable aid of Tamiya masking tape especially the 2mm flexible one for curves.
                    Removed the roundel/number decals as they just didn't look right to me.
                    The Gulf sponsor decals will do.
                      Fantastic build as always, Dan. The dark blue looks good on the car, in my opinion. Wish we would see this body again....another rare but excellent looking car.
