Cartrix Acura NSX - hybrid re-chassis
  • Cartrix Acura NSX - hybrid re-chassis
    Got a pile of the Cartrix Acura NSXs after seeing a review on HRW many years ago.
    Curious to see how one runs with a hybrid chassis so the build begins.
    Cut metal for the chassis including,
    .055" piano wire - main rails and front axle supports
    .062" x 3/4" brass strip - guide tongue/front axle support
    .062" x 1/2" brass strip - guide tongue
    .062" x 1/4" brass strip - motor pod support cross members
    5/32" brass tube - guide tube to be bored out to 9/64" for Sloting Plus Universal Guide, 7mm deep
    1/8" brass tube - front axle tube
    Motor pod's a 3DRon sidewinder S can resin printed one with Parma 3/32" x 3/16" axle oilites.
    Soldering begins.
    Chassis components soldered together.
    Ready for rolling components and motor train for a trial run.
      Clean work Don, nice job.
        Chassis's running with these assembled parts.
        front wheels/tires - stock Cartrix plastic/Slot It low profile low friction
        rear wheels/tires - Mitoos 19mm/home made urethane
        motor - Piranha 25K S can
        pinion/crown gears - Slot It 10t/Slot It 36t
        guide - Sloting Plus Universal, 7mm deep
        Tri-post mounted the body as usual.
        Cut and filed the original rear plastic rims into wheel inserts.
        Has good stick in the corners and plenty of speed. A bit noisy with the mounting screws all tight but some loosening cut that down noticeably.
        Onto the next build.
          Dang! Dan, thats Sharp!!
