Scalextric Peugeot 908 HDI - re-chassied
  • Scalextric Peugeot 908 HDI - re-chassied
    Picked up a Peugeot body from a fellow member with the intention of installing one of my adust-o-wheelbase hybrid slimline motor chassis.
    Click image for larger version  Name:	IMG-7856.jpg Views:	0 Size:	89.3 KB ID:	43709
    Click image for larger version  Name:	IMG-7857.jpg Views:	0 Size:	81.6 KB ID:	43710
    Click image for larger version  Name:	IMG-7858.jpg Views:	0 Size:	83.2 KB ID:	43711
    Click image for larger version  Name:	IMG-7859.jpg Views:	0 Size:	72.3 KB ID:	43714
    Power's a Scalextric Sport 25K motor with a 3.1:1 gear ratio from Slot It 9t pinion and 28t crown gears. Wheels are Slot It 17 x 8 all around with Slot It low resistance front and home made urethanes out back.
    Click image for larger version  Name:	IMG-7836.jpg Views:	0 Size:	110.7 KB ID:	43712
    Body was pretty carved up front to back for guide swivel and chassis and wheel clearance especially at the back.
    Click image for larger version  Name:	IMG-7843.jpg Views:	0 Size:	87.2 KB ID:	43713
    The exposed crown gear and motor pod were necessary as the body's pretty low back there. Could bother some and not intended as a proxy entry. I'm good with it.
    Tri-post mounted the body to take advantage of the side pan flex.
    Only cosmetics were fabricating a front splitter from .030" styrene sheet. Nice taking a break from the modeling work that takes me a lot longer than just the chassis.
    Click image for larger version  Name:	IMG-7852.jpg Views:	0 Size:	96.2 KB ID:	43715
    Click image for larger version  Name:	IMG-7853.jpg Views:	0 Size:	92.5 KB ID:	43716
    Click image for larger version  Name:	IMG-7854.jpg Views:	0 Size:	97.7 KB ID:	43717
    Click image for larger version  Name:	IMG-7855.jpg Views:	0 Size:	72.8 KB ID:	43718
    Stance is good.
    Weighs in at a hefty 106 grams so has a quite a planted feel on the track.
    Drives well but would like it lighter so more weight reduction is in order.
