Building a 40 Ford Tudor sedan for a friend.
Started off with one of my slosh casts, the mold created from a vintage AMT All Stars Ford.
Not an easy body to slosh with the mix of 90 degree vertical and horizontal surfaces. Usually have to add material (resin or epoxy) at the joints as that's where they end up being the thinnest.
Put together my usual adjust-o-wheelbase chassis with a slimline motor pod. Using RS Slot Racing RSW 002 15" rims with Paul Gage tall tires (3mm rib width).
Tri-post mounted the body, my preferred method these days.
Body stance looks good to me, not too low or high.
Tires aren't rubbing so we're good.
Should be running soon.
