1/24 Sunbeam Tiger build 1 - rechassied with a sidewinder layout
  • 1/24 Sunbeam Tiger build 1 - rechassied with a sidewinder layout
    My build 2 with a sidewinder motor layout worked out so well...
    https://www.homeracingworld.us/viewt...p?f=45&t=21402
    ...that I'm going to rechassis my first Tiger build from almost three years ago with the same chassis.
    https://www.homeracingworld.us/viewt...p?f=45&t=15613
    Pieces cut and parts assembled.
    - .055" piano wire for the main rails and front axle uprights
    - .064 brass strips for the guide tongue and cross members
    - 5/32" brass tubing for the guide post to be bored out to 9/64" to accept a Sloting Plus Universal guide, 7mm deep
    - 1/8" brass tubing for the front axle holder
    - Mitoos 19mm and 17mm rims with home made urethane tires
    - 3DRon S can motor pod to accept 3/16" x 3/32" oilites
    Click image for larger version  Name:	IMG-6973.jpg Views:	21 Size:	104.0 KB ID:	3273
    Body work will include a new driver figure, rollbar and roundel number decals.
    Should be rolling soon.
    Pretty cool Dan, like that pod, nice body-
    I printed one of Chappy’s Tigers stretched to 1/24...almost ready for primer..hope it comes out as nice. Brass going under it.
      Base chassis soldered up with screwed in motor pod. Sits flat so that's a good beginning.
      More finicky part of getting square is next. My honeycomb soldering board is not as exact as some of the commercial ones, so I do lots of measuring checks to ensure wheelbase is identical on both sides. Just got to be patient and take my time.
        Chassis's running with a power train of Slot It parts including a 25K S can, 11t pinion and 38t spur. Re-used the Mitoos 19mm and 17mm rims with home made urethane tires. Guide's my go-to Sloting Plus Universal 7mm deep.
        Tri-post mounted the body.
        Cosmetically, changed to a Fujimi driver figure, installed a smaller diameter rollbar made from 1/16" piano wire and applied a number decal.
        Runs smooth and is more driveable than with the previous inline motor set up.
        Good refurbishment.
          Beautiful car and chassis!
            Very nice looking car
              An absolute BEAUTY
              TOM...HOME RACING GOO GOO!!!
              Warren, Ohio
