Carrera tuning
  • Carrera tuning
    I have the Gulf blue Carrera Porsche 904. Beautiful car, but it needed some fine tuning. In no special order here’s what I’ve done.
    The guide flag post is a loose fit in the chassis, which causes the flag to wobble. The design also puts more weight on the front tires than I like. A friend sent me a prototype file for an adapter, which I printed at my library:
Name:	flag adaptor.png
    I also printed a guide flag that I found on Thingiverse (“Slot car guide” by wayne69x):
    I then carefully removed all the Carrera parts and started cutting/filing/sanding the adaptor and flag until they were a good fit. I used some shims to set the front tires .010” off the track, then used self-leveling silicon sealant to hold the adaptor in place. Not as strong as CA or epoxy, but I can revert back to the original Carrera parts pretty easily:
    While doing this work I also simplified the wiring:
    If you held the chassis in one hand and grabbed the rear tires in the other, you could feel a good deal of play. I could see the bushings moving around in the chassis, as well as the axle moving in the bushing. I decided the first step was to glue the bushing in place. I again used silicon sealant, it holds well enough and is very easy to remove if needed:
    Once the bushings were glued I checked the play again, and it wasn’t bad. So for now I’m not going to bother with the "CA fix" to remove axle slop.
    Next I spent some time using my fairly new Tire Razor, which I’m pretty happy with:
    The last modification was magnets. The car comes with a long bar magnet in the middle, and a somewhat shorter one in the rear. Both have metal shims, a nice touch that gives you more options. However, those two magnets are way too much downforce for me. I like my cars to drift, so I use only light amounts to try to get them close to the same level of performance.
    I removed the rear bar and set it aside. I then removed the middle bar, and replaced it with two old “dot” magnets. If you’ve been around for a long time, you may remember them from the Scalextric Kodak NASCAR:
ID:	97215 Click image for larger version
    That wasn’t quite enough. Poking around I found a shorter magnet that I pulled from another Carrera:
    Because it was so much more than the dots, I first tried it with the metal shim between the magnets and the track:
    That was pretty good, but for “performance equalization” I ended-up with the shim on top:
ID:	97219 I'm much happier with how the car drives now. I’ll live with it like this for a while, and then decide if it needs any other tuning.
    Ron
    Nice set of tips and photos for tuning the Carrera cars.
      Just so you know the guide flag adapter is already available .
        Here is the other version also
        • oz10k
          oz10k commented
          Thanks, these look great and that's a reasonable price! I'll pick one up for my next project.
        Hey, well done. Appreciate your post.
        And wow...the button mags from the first NASCARS! (I remember)
        Here is the link to the full playlist I did for the GT cars. I used the CG Slotcars adaptor.
        • oz10k
          oz10k commented
          Wow, excellent playlist Harry!
