I contacted Milan to build me this car at the end of January and received it a little over a week ago. This is the Sauber Mercedes C291 body with a Laminate chassis. Front foam tires and Rear rubber tires. I didn't specify the gearing and I don't know what motor that is. I've sent him an email asking him for the details.
One thing I'm thinking about modifying is the rear motor pod "suspension". I think that if I replace the nuts sandwiched between the chassis and the support arm with springs, I could have an active spring suspension. The current setup with the spring on the center support really doesn't function because of the stiffness of the material used.
Does anyone have one of these chassis? What changes have you made, if any?
