I was thinking about trying some of these, so any info would be appreciated. I really would like to know how tall they are and if they will work on a routed track with tight turns and no magnets. I have the Trackmate lap timer/counter and an overpass, clearance is about 5".
FlySlot truck questions
I don't have any in front of me to measure, but I'm sure they can be made to run on routed wood. There was a national event for this class a few years ago and they were run on many different tracks in preparation. It's all about weight tires and tuning. Same with any other car. I've seen almost no weight and more weight than I'd know what to do with. Tune to your driving style and they are a blast to drive.
Originally posted by Bal r 14 View PostI was thinking about trying some of these, so any info would be appreciated. I really would like to know how tall they are and if they will work on a routed track with tight turns and no magnets. I have the Trackmate lap timer/counter and an overpass, clearance is about 5".
FYI, we allowed swapping out of the running gear for Slot.it gears, axles. We also used the NSR truck aluminum rims. We retained the original motor as they’re ok. I’ve geared my truck at 2.5 (25:10); although, I’ll probably change it 27 or 26:9 at some point. We’ve added weight to help offset the top heavy-ness. My Buggyra (sp?) has a “dogbone” chassis, which doesn’t leave much room for weight, but I’ve packed it in there. The flatnosed Mercs seem to be lighter and have a more traditional flat chassis where you can add more weight.
also, I retained the sprung guide. For some reason it’s worked better than adding in a Slot,it guide (I know...against all logic!). We race on urethane tires (Paul Gage, typically the PGT 40 Shore), at 10.5v on flat matte latex painted tracks.
Hope that helps! We enjoy these, they are a definite challenge to race. Really separates men from the boys re driving skills.
Cheers, eh!
Tom
Founding member of Rocky Mountain Racers, a 1/32 club based in Calgary, Alberta Canada: http://www.facebook.com/rockymtnracers
Actually I got the rims wrong. We used the sideways ones (https://slotcarcorner.com/products/sww-tr02-mg-sideways). Re tires, for the fronts, I can’t recall but for the rears, I believe I think was 21105LM? Sorry it’s been a few years, but Paul does have specific tires, just don’t know if they fit the Sideways or NSR rims... https://slotcarcorner.com/collection...ane-tires-firm
Hope that helps
- Likes 4
OK, sounds good to me. One more question, I see prices from $69 to $99, in some cases the trucks are virtually identical except for the number and slight differences in decals. Is there more than one version and are expensive ones significantly better? Oops, two more questions: are they angle winders or side winders?
Yes these are a blast to drive. Each has been upgraded with a new guide and insert - it transforms the drive and is a must-do item IMO. And add lights to run them under the lights. I used this front/rear axle upgrade kit on 2 of them - and in 2 of them I swapped the original motors for baby Sprinter 18K units.
I have a Buggyra also but it's never been out of the box... yet!
How many trucks are you looking for? We used to run the trucks but haven't for quite some time, I can find out if they want to part with any of them.
Shipping would be from Ontario, Canada so I'm not sure of the shipping cost or how long they would take to arrive. I've been waiting over 5 weeks for a package from CA.Brad
Ayton, ON Canada
Originally posted by Brad_T View PostHow many trucks are you looking for? We used to run the trucks but haven't for quite some time, I can find out if they want to part with any of them.
