Chaparral 2E
Interesting build, Dan. The file looks fairly reasonable, although maybe a bit thick. But some are like that.....
I have been considering using this as a base for a 2G file.
Slot.it glass will probably be pretty close, I would think, unless you changed the file when you printed it.
All you folks doing decals are really making me think I should try......
Show the chassis, too.....those builds are also interesting. Pretty soon you will have a full CanAm grid too.Come Race at The Trace!
Yes this is a thick print. I took the Dremel to it after it was printed out. I wish the 3D software I am using had a digital dremel tool so this could be done in the software. Sure would be a nice tool
Re Glass. Found some on ebay, but with crazy shipping it was a non starter. I do vacuum form most of the glass I need, and this chaparral print had the glass molded in. So I sliced it off and saved it as a glass file. I am working on about 5 cars right now. Once they are done I will pull out the vacuum former and do the glass for all of the project cars that need it.
DanLast edited by Barc 1; March 18, 2021, 01:32 PM.Cheers
G.P Alberta
Meshmixer allows you to thin some models. You can also make a copy and "subtract" it from the original which can help.
Originally posted by chappyman66 View PostMeshmixer allows you to thin some models. You can also make a copy and "subtract" it from the original which can help.Cheers
G.P Alberta
