For chassis oiling, bearings etc, is 3 in 1 oil ok or will it do bad things to the plastic ? What other oils or greases are a better option?
Oil , is 3 in 1 oil ok to use?
Some oils work at least a little better than others. If you race your cars using a better type of oil would be more important. For a start use a brand of oil that is plastic safe, the wrong oil will attack plastic and make it brittle. If you use oil that is very thick the car will run more slowly until it warms up. I have done a little actual testing and I use Superlube, which is a plastic safe synthetic oil with micronized Teflon suspended in it.
..or direct from SuperLube itself: https://www.super-lube.com/multi-use...-syncolon-ptfeStan S.
Newberg, OR
Autodromo Rossa Colline (Red Hills Raceway)
Slot Car Corner packages Superlube in needle tip applicator bottles. I recommend this one: SCC Slicker-N-Snot Racing Oil, 1 oz. (slotcarcorner.com)
I switched from the 3 in 1 over to using some 0w40 Mobil one synthetic oil. I read somewhere else that it is plastic safe. On the front axles after cleaning off the 3 in 1 they spin much better with the Mobil 1. I donβt think it will ever get warm enough to get beyond its 0 rating. For my home use it seems to work nicely.
