I have a pretty good handle on my HO tire storage needs, but not for 1/32. So... how are you guys storing and organizing your tires? PM has a "PMTR1300 Small Size Tire Tubes". Those look good, but they're out of stock. Looking for something that will work with Plano tackle box trays. Ideally, I'd like some containers that will fit 2 or 4 tires, and fit in a Plano tray.
Tire Storage
Originally posted by GearHead36 View PostI have a pretty good handle on my HO tire storage needs, but not for 1/32. So... how are you guys storing and organizing your tires? PM has a "PMTR1300 Small Size Tire Tubes". Those look good, but they're out of stock. Looking for something that will work with Plano tackle box trays. Ideally, I'd like some containers that will fit 2 or 4 tires, and fit in a Plano tray.
Silicone and urethane tires can be stored at room temperatures. The only reason for putting them in a special container is so you can tell what type and size they are. Larger diameter tires may not fit in pill bottles. Foam and rubber tires should be put in sealed containers and stored in a freezer if possible.
Originally posted by War Eagle River View Post
Originally posted by RichD View PostSilicone and urethane tires can be stored at room temperatures. The only reason for putting them in a special container is so you can tell what type and size they are. Larger diameter tires may not fit in pill bottles. Foam and rubber tires should be put in sealed containers and stored in a freezer if possible.
Rubber tires tend to get hard or turn to slush as they age, storing the tires at low temperatures slows that down. If rubber tires are formulated properly they can last a long time without taking special precautions, but you can't tell if a particular pair of tires has been formulated properly until it is too late. Sandwich bags are actually somewhat permeable.
Another solution to the tire storage issue is spend a lifetime eating burgers and fries with large chocolate shakes, salami sandwiches with potato chips and a slice of apple pie, pizza with lots of pepperoni or sausage or both, and eventually you'll end up on multiple meds for high blood pressure and cholesterol that will ensure a constant supply of pill bottles.
It's a tried and true system. You can quote me on that.
- 1 like
