So the dilemma is that my Ninco pinion press is too short to press a brass pinion gear onto a motor with a spring mounted shaft extension. The motor is a front mounted in-line motor in a Shelby cobra coupe by MRRC. I have tried various ways of doing it but without any success. (never very good at puzzles) I am sure someone at HRW has figured out how to do this. Please share your solution?
Pinion press dilemma.
If I recall correctly, the rear section of the shaft can be "unscrewed" relatively easily because of the helical nature of the spring. If you turn the rear shaft one way it will be tight, but if you turn it opposite the direction of the spring coils it will loosen up and with slight pulling traction you can extract the shaft from the spring. Then with just a shaft and the pinion you can use a block of wood with a hole in it with the one end of the shaft in the hole and the pinion resting on the wood, gently tap the other end of the shaft to properly seat the pinion to its' correct placement. Once you get the pinion on, to the right position, then "screw" the rear shaft back into the spring.
Peter
You will need to remove the shaft from the spring,.....then,.......cut a piece of brass tubing that the pinion shaft will fit into (maybe 2 inches long), cut another piece of tubing/piano wire that will fit inside the first cut piece of brass tubing (cut this one maybe an 1.5 inches long)......telescope the 2 pieces, and insert your pinion shaft.....stick this whole mess into your press, and Bob's your uncle.
Sounds confusing, actually quite easy.........or get a press with a much longer adjustment screw
Petes' method (above) will work just as well.
I just remembered something else... I think one time I actually ended up pulling the rear shaft and the spring off together. In this case I just used some pliers gently on the spring to remove the spring from the rear section and then reassembled everything again once I had made my modifications.
Peter
Of course, if you want to use the spring method of coupling, it would be worth the bother you will have to do. But we (HRW) long ago avoided the problem by using a section of ball point pen ink tube to join. Its the perfect size, there will never be a vibration problem. Most of the time, a tiny dot of Superglue will be enough tack to hold everything in place. You can also use vinyl tubing like that used as fuel line in gas motored airplanes and cars.
