As noted in other posts I'm working on building a group of 1:32 scale sprint cars. I bought a bunch of Predator motors from SCC and 4 LVJ sprint car chassis from Professor Motor before finding out they are incompatible due to differences in how motor mount holes are aligned. The LVJ (Parma clone) chassis have vertical holes and the Predator motors have diagonal (FF-050) or horizontal (FC-130) holes in the can. But, when I looked in my motor bin I found several Professor Motor PMTR1500 Hot Rod motors that should easily fit in the LVJ chassis.
I'll build up a few LVJ chassis with the PM motors, then probably build some simple brass chassis using SCC motor mounts that fit the Predator motors.
Brew chassis design (top) & LVJ chassis (bottom).
The issue will be if and how to equalize chassis powered by 26K PM motors with chassis powered by 18K Predator motors? The LVJ chassis with 26K motors will be heavier than the chassis I build using Strangebrew's lightweight chassis design, but I don't know if that will be enough. On the 1:1 dirt modified racing circuit when an event was open to both big block (467 CU) and small block (358 CU) cars the big block cars generally had a 200 lb weight disadvantage. This seemed to make the cars relatively even resulting in good racing.
Is it likely doing something similar with the sprint car chassis can have the same effect? Or, can the motor differences also be addressed with different gear ratios? Any suggestions on ways to equalize these cars with different motors are appreciated.
