Oscar, Elvis, & Charlie - My Thunderslot McLarens
This bear’s repeating!
Absolutely positively the BEST in depth video ever done on the ThunderSlot’s. Very well done, thank you!Scott.....War Eagle River......Tampa, Florida, USA
Thanks folks.
Around here it's just random most times. I TRY and mix things up and test different sizes and compounds for the reviews.
But I normally use silicones on models with aluminum wheels. Since the tires are designed for those specific wheels, they don't require sanding.
On odd size wheels like Carrera and older models with plastic wheels, PG is usually the choice so I can sand/contour to get them just right.
For our Showdown and other events I like PG. The tires give a little more drift for the oval cars.
Again, I like the videos and I appreciated the time and effort put in!
There was a moment. . . a moment when you de-slotted, and you said "spin out", then a pause, then an "ahem" . . .
I see what you did there.
