Picked up an analog Carrera set recently.
Want to replace the factory “plunger style” analog Carrera controllers with a trigger style. Looking at the Professor Motor 35-ohm model reviewed here – I see there is an electronic model (Carrera Home Set) for a little more.
I’m a part time rug racer – so I don’t want anything to elaborate. Track is small and flat – cars will mostly be Slot.it at this point.
I think the analog Carrera controllers are around 60 ohms – and from what I’ve read might be a bit high anyway for the Slot.it motors and 35 ohms may be better suited to them.
Does the PM electronic controller automatically adjust to each car it sees on the track (i.e. how does it work)? What is the advantage of going electronic?
