I’ve installed many of these, and my trusty Slot.it pinion press / Puller does the job without fail.
Until now, never had to pull a 1.5 mm pinion off of a predator motor. The Slot it pin pusher on the extractor is too thick to go through the pinion.
I installed an 8 tooth pinion and want to switch to a 9 tooth.
any thoughts or suggestions?
thanks
thanks
