Motor identification needed.
  • Motor identification needed.
    I have a FF50 slimcan that has been stamped, “SPEED 1”. It has has an elongated oval as the opening in the can.
    Does anyone know the manufacturer and specs for this motor?
    Thanks
    G.P Alberta
    SRP motors are tied up with MRRC and I think I recall correctly that the Speed 1 was an 18k version although they also had a 16k version so the pendulum could swing that way too. They were available in NZ a while ago and I did buy some but can't recall which cars they ended up in although more recently I have taken to writing on the chassis with a silver Sharpie to try and negate my withering memory..
    Bram,
    CHCH NZ
      Thanks. It performs like an 18 K motor, and the info you gave me helps identify it for proxy racing
      G.P Alberta
        You used to be able to find all the info on the SRP motors on the MRRC website, but the entire motor section has been removed recently.
