Hi guys, I am stumped as to why two used Ninco cars I recently picked up on ebay, ( yes the dreaded ebay to some), are not working. I bought a used Ninco MT900R race set and both the cars (Mosler MT900R's if you don't know)have angle winders in them. The motors were unsnapped from their mounts when the set arrived, so I re-snapped them into place and tried them on my track. They both worked and completed several laps but were very noisey! I lubricated the gears and also hot glued the motors to the chassis, because they had alittle play in them. I got this idea from a video I had seen on tuning cars. When I tried them again they were alittle quieter but they also would stop almost immediately and needed to be pushed to get going again. Keep in mind i cleaned the track that day as well. After removing the bodies I could see that the gears are not meshing well with the pinions. These are stock gears I believe and made of plastic. The axle also has a red spacer on them which I don't understand the purpose for?
So what is going on? Should I have left the motors unglued? Do they need the play in the motor mount to compensate for the crappy gears? Are the plastic gears and pinions worn out and need replacing? Does the red spacer have something to do with the set-up?
These are beautiful cars. The bodies are comparable to any of my FLY's. I would love to get them running again.
I would post a picture, but...
