I'm building a new banked oval with crossovers at each end of the track so a solo car will cycle through all 3 lanes. Most of my oval cars are custom built using the larger Parma or Champion commercial track guides and tests suggest they will negotiate the crossovers just fine. But, a battery powered test vehicle with a small RTR guide (Monogram?) didn't always follow the intended route. When going through a crossover on lane 3 that was intended to divert it to lane 2 it often had it's momentum deflect its guide so it remained in lane 3.
I think the key to having the crossovers work as intended will be enlarging the keel on smaller guides using glued on thin plastic stock. I know others have done this and am looking for tips on what has worked. The slots on this track are 1/8th inch wide & 5/16th inch deep. I want guide keels to be 1/4" deep but not more than that. More importantly, the needed upgrade is increasing the keel's length. Would it be best to extend it forward, backward, or both? And what contour did you use for the extension (rounded, slanted, etc.)?
The problematic small guide on the test vehicle is around 5/8th inch long. The Parma commercial track guide is 1 inch long. The red Carrera guide keel is 3/4 or 7/8 inch long.
