MR Slotcar Marlboro McLaren
  • MR Slotcar Marlboro McLaren
ID:	44335I just received the McLaren F1 GTR #2 Marlboro and what a beauty it is! The car features a Slot.it Yellow Flat 6 motor in a newly design pod but it also comes with a second pod for a King type motor.
    The chassis design is extremely well thought out and the moulded chassis and pod is some of the best I've ever seen. The pod has four point mounting and ample room for float. The front axle is held by uprights that screw into the main chassis allowing the use of stub axles for independent front wheels or sprung front suspension with the optional kit. The body is very well, moulded, painted and detailed. Lights can be easily added too. I trued the stock tires and will run the car tonight.
    Love that livery/car! Looks great and like it'll run very well. Thanks for sharing!
      Excellent purchase! Great livery the new one is also great looking its the blue Jacadi livery we got this running very competitive with nsr 5214 rubber in our gt class. We run all nsr rubber. Once it comes in hold on tight. Mrslot is a great brand!
        Thanks for the tip on the NSR tires.
          I bought the NSR 5214 Tires but they are a bit wide for the stock rims. Are you using a different rim for these tires?
            I have one in the USPS system somewhere between New Hampshire and my house.
              So you can leave them on stock wheels and glue and true them. We use nsr air wheels and axle. True and glue. Yes you will have to round the edges on both stock wheels and nsr wheels so they fit just right.
                All try and post a picture of my mrslot car with the 5214 tires glued and trued.
                  So do you round the edge of the wheel with a file? Im guessing you do this on your tire truer? Thank Bob
                    how does the car handle
                      Yes, I’d like to know also as I’m swearing this will be my last (2nd) slot car purchase of the year. I swear
                      The Jester
                      Soxside (Chicago)
                      • Brumos RSR
                        Brumos RSR commented
                        I mean it
                      • Rleog
                        Rleog commented
                        šŸ¤žšŸ¤žšŸ¤ž
                      Handles great! Looking for a bit more speed for my local track. Gearing is 11/29. Need to see what other gear options MrSlotcar offers.
                        Sorry guys I ment to say round the edges of the tires. To fit the wheel wells. Not the wheels my apologies.
