While trying to remove the rear tyres off the #22 Monte Carlo Nascar, which are soooo tight on the rim (almost like they are glued on) I split the rim boss area and the wheel came off the axle. Managed to refit it and glue the damaged area and the wheel looks to be running fairly true, as far as plastic wheels go. Lucky only one side damaged, was going to fit PGT on the rims but
the original tyre just wont come off!
Any one else had this issue ?
The car is only a month old and hasn't run a heap of laps. I hadn't even trued up the original tyres, the other Monte I have has PGT fitted with no problem
I will contact the shop I purchased from and seek an answer
