I received a message from a forum member asking about the 55 Chevy in my avatar and if I could add some photos of the process of changing the coupe to a sedan.
There are quite a few photos so here goes. Enjoy and hope they are of use.
The roof needs to be cut at the highest point and also carefully cut around the back so as it can sit on the panel in front of the trunk.
The window of the coupe version is slightly shallower than the sedan so sitting it on the panel gives it more depth without drastic surgery.
and sitting in place. I used a photo of the real thing for correct placement.
Next thing is to glue strips of styrene under the gap so there is something to attach the filler piece too.
Also the window line needs to be brought up to the correct height and the B pillar added.
The hood needs to be filled and centre line attached.
After the roof has been filled the fun part starts. Filling and sanding and filling and sanding and
more filling and sanding and filling and sanding
A before and after
and the body sitting on a shortened Pioneer Charger chassis awaiting paint
and presto
and the photo where my avatar comes from
A before and after
and presto
