Lotus 23 C
  • Lotus 23 C
    Rebuilding some earlier cars to pass some time. This is a Lotus 23 that was carved from wood to make a master and then I used that for a silicone mold, so I could pop resin shells.
    Rebuilt the chassis using a brass plate and repowered the car in a sidewinder layout with twin cans. Two Mineabea BARC motors. This allows lots of room for a full interior even in a small car like this
    Wheels are Cox Mag wheels
    Driver is made out of white scenic foam sheet cut to shape and I added a resin head.
    Seats are also built out of scenic foam. Painted and then had pleat lines cut into them
    Seat belts are made by painting a thin coat of acrylic craft paint on parchment paper and allowing it to dry. This paint can then be removed from the parchment paper in a sheet. I then cut it into strips and position the belts where required. A thin wash of decal setting solution is used like glue to position the belts.
ID:	30675Click image for larger version
ID:	30676Click image for larger version
ID:	30677Click image for larger version
    G.P Alberta
    wow that's nice. many years ago i got to race one a few times. but it didn't look That good!
    speedy
      Beautifully done. A work of art.
      Bob G. ..... Boston, North Shore
        That's great work Dan.
        Chris aka CJR RACING Denver, Colorado and Nagasaki, Japan
          Really nice!
