I am wanting to install a plastic pinion gear on a slimline motor with a smooth shaft. Might anyone have some suggestions on the best way to rough up the smooth shaft prior to installing the pinion so that the hold can be secure?
Best way to rough up a smooth shaft for a plastic pinion gear?
I have also had good luck just pushing them on with some red loctite on the shaft after using a scrotch brite pad. Haven't had a problem yet!
Zack
A little rough up with some 220, then use some Loctite 271. Also know that there is a difference in the Loctite products. Red 262 is medium strength, 271 is high strength. But why use a plastic pinion?Last edited by War Eagle River; March 9, 2020, 07:08 PM.Scott.....War Eagle River......Tampa, Florida, USA
I use 220 grit paper, I clamp the other end of the shaft in a vise and then pull the 220 along the length of the shaft 3-4 times making sure I roughen the entire diameter. I then simply press the shaft into place with my gear press.
no need for any glues. I use this method on my 1/24 Scale Auto cars with zero failures.
Thanks for this discussion....it made me think I should upgrade my aging pottle of Loctite 262.
On the shaft roughening topic...in the past I have heavily scored the shaft with sidecutters but these days just something that takes the shine off is enough. Sometimes I just dont bother and rely on the new clean shaft and the new clean pinion before adding some red stuff.
